need help. air cleaner oil
Old 02-07-2015 | 08:00 PM
SugsPa's Avatar
SugsPa
Make sure engine oil is not over filled, if new air filter was installed you should be good there. Previous replys are good answers, how I solved my problem.
SugsPa
Old 02-07-2015 | 11:21 PM
Buelligan666's Avatar
Buelligan666
A couple people mentioned over filling with oil. How does that cause oil to come out of the breather? It's a dry sump system. The oil tank is just a reservoir. The oil pump pumps the oil out of the reservoir and through the motor and it returns to the tank.
I like the article about blow by. Blaming it on riding to easy. I've always been told and read there's 2 schools of thought on breaking in an engine. Run the ***** off it to seat the rings better, or baby it so it doesn't get damaged in it's early life. I always believed in running it and seating the rings. I have no blow by in any of my bikes.
Old 02-07-2015 | 11:36 PM
Hogster 1's Avatar
Hogster 1
I belive you to be a new member, If that is the case I would highly reccomend the search function...
There aint to many things these ole boys haven't seen
Old 02-09-2015 | 12:06 PM
Golfinds's Avatar
Golfinds
Thanks for the responses. It might actually be fuel that spits when the bike does a little backfiring on deceleration. That pop sorta speak. Either way it just started after 13k miles, I just need to figure out why
Old 02-09-2015 | 01:34 PM
DK Custom - ST's Avatar
DK Custom - ST
Platinum Sponsor
Below is a link on Oil drips, blow-by, What is really the correct oil level, this may help you out
https://www.hdforums.com/forum/oil-r...oil-level.html
Kelsey
__________________
Cristy
FREE SHIPPING - ORDERS OF $100 OR MORE - LOWER 48 STATES
www.DKCustom.com
Call: 662-252-8828
Text: 662-420-4891
http://i1088.photobucket.com/albums/i339/DKCustom/Links/Sig1-8-14_zps9d8aff35.jpg
Old 02-10-2015 | 12:20 PM
mouser58's Avatar
mouser58
My 2005 Road King did that.. first time was caused by cracks in the hoses coming out of heads into the breather and when it happened again, my mechanic said it is caused by lugging the engine too much, especially in high gear... He recommended not using 5th gear below 50 MPH.. I put 3000 more miles on it and no more oil in air filter...
rlj50
General Topics/Tech Tips
07-27-2014 02:41 PM
BigTwins
09-05-2013 08:15 PM
HarleyReece
10-07-2011 06:41 PM
Sheazo
Oil Archive (no new posts)
05-26-2010 10:45 AM
djkuma
Exhaust System Topics
04-15-2008 01:47 AM
Quick Reply: need help. air cleaner oil
