Highbeam and passing lamp mod ??
Old 04-19-2007 | 01:27 AM
bdjhog's Avatar
bdjhog
Default Highbeam and passing lamp mod ??
I must be an idiot cause this is confusing the hell out of me, can someone explain what I am looking at here? What exactly do I have to do to make this work? Thanks.
Old 04-19-2007 | 01:30 AM
dawg's Avatar
dawg
Default RE: Highbeam and passing lamp mod ??
When you take off the outer fairing cap and you are looking inside, look to the back of where your accessory switch would be and to where the back of you spot light switch would be. Then look for the same color wire that is shown in the diagram. Cut the yellow wire where it goes to the headlight connector and tape off the stub. Take the remaining end of the wire that you cut and tie it to the orange/red wire from the accessory switch
dawg's Avatar
dawg
I found it easier to see after I removed the radio!
Old 04-19-2007 | 01:32 AM
TexasRedneck's Avatar
TexasRedneck
Here's a coupla pics of the completed job....
[IMG]local://upfiles/19857/957213A55EE74DD6A568AA95657CD5FA.jpg[/IMG]
[IMG]local://upfiles/19857/80E87295C0DD4DF09544A6C2D4841ADC.jpg[/IMG]
Old 04-19-2007 | 07:44 AM
PapaTravis's Avatar
PapaTravis
Is this the proceedure to make the passing lamps stay on when the high beem is on? If so, will the pictures and diagram above be the same for a '05 rk custom? And I am assuming that I can get to this by just going through the head light nachelle? Is this a correct assumption?
Old 04-19-2007 | 09:39 AM
jbhawley's Avatar
jbhawley
follow the pics from texasredneck. they are on the money. It took me maybe 30 minutes to do this, and thats waiting 10 minutes for the soildering iron to get hot.
Old 04-19-2007 | 10:01 AM
Lil Truckr's Avatar
Lil Truckr
Redneck,
I noticed that you have your HD service manual laying open to the schematics in the background of your two pictures. Can you tell me what plug number is assigned to the plug your doing the modifications to?
Thanks...
Old 04-19-2007 | 10:08 AM
bdjhog's Avatar
bdjhog
Thanks guys. That's what I needed!!
Old 04-19-2007 | 11:24 AM
TexasRedneck
Lil Trucker, there's only one plug involved on this mod - no way ta make a mistake. It's the one ya hafta disconnect to remove the inner panel with the switches on it.
Old 04-20-2007 | 10:51 AM
Lil Truckr's Avatar
Lil Truckr
Got it, thanks TR.
Quick Reply: Highbeam and passing lamp mod ??
