I have a 2001 Ultra Classic that the cruise control does not work. I checked the codes and it gave me code 122 front or rear brake light switch. The brakes are both working the light properly. I replaced the rear switch anyways tonight and the cruise still does not work when you go to engage it. The panel light comes on when you engage the cruise switch. I even rode at 50 mph in 5th gear. But still no cruise. I even replaced the cruise control module and cable and did the cable lashing test. Any help would be greatly appreciated. Thank you.
Hello, my cruise doesn't work, I thought it was just disconnect the roll switch, this says jump them together, I will try this, but I don't even get the "C" light on the tacho, will try it tonight, thanks
