bagger bars
#31
2010 Limited with some stuff!!
#32
Get yourself a MityVac and bleed your brakes with it. They're pretty cheap. The key is, do not turn your ignition on until you've bled your brakes. Turning the ignition on cycles the ABS unit and if you haven't bled your brakes it will trap air in the unit.
Thanks SBates.......... That is exactly the kind of info I was looking for.
72camaross
04-27-2012 07:12 AM
