Trouble getting bike in neutral
Just recently installed a FM107 engine upgrade and updated the clutch spring to the heavy duty clutch spring from Barnett. The trouble I'm having now is when at a stop the bike is nearly impossible to get into neutral. I have adjusted the clutch at the basket tightened bolt till just barely snug and then backing it out 1/2 turn. I also have adjusted the clutch cable till the clutch begins to grab about 3/8 of an inch off the grip. Running mobile 1 full synthetic in the primary. What gives? What am I missing? Thanks in advance guys.
I wouldn't run synthetic in the primary but that is probably not the problem.. Did you loosen cable before adjusting the center clutch bolt?? The directions in the manual should work. How did you check the oil level in the primary? Is it possible you added too much oil? Did you take anything apart other than the diaphragm spring cover when you swapped the spring?
difficulty finding neutral is 95% of the time misadjusted clutch or primary chain tension.
calls for a do-over.
while some riders suggest adjust a warm clutch...my manuals say room temp. so that is what I do.
2.) if you just changed primary lube, did you get all the old stuff out? the clutch disks absorb fluid & if your 2 fluids are not compatible...
mike
mike
Likely an issue with not enough clutch disengagement post new clutch spring install so try adj more clutch disengagment and hopefully that should do the trick.
Scott
I followed there direction and it started to slip real bad (bad like bike literaly jumped) when bike got hot. went back and did it closer to the manual upper limit problem solved
