What speed in 6th gear?
Old 04-18-2007 | 09:46 PM
springerGT's Avatar
springerGT
Default RE: What speed in 6th gear?
What are the oil spills on the floor coming from?
GT
  #32
Old 04-18-2007 | 09:53 PM
nvsteve's Avatar
nvsteve
Just my opinion, but you guys that are running around at 55-60mph in 6th gear are not doing your motor any favors, no matter how happy your motor sounds.
  #33
Old 04-18-2007 | 10:08 PM
the_icemAN's Avatar
the_icemAN
interesting topic.
I guess experienced riders know best.
When I got my 07 ultra I was told by the dealership to NOT have the RPMs < 1500 or that is considered lugging for the 07s. You can definately hear/feel the lugging at 1500 rpms on a stock setup.
I was told by the dealership and the owner who seems to own a dozen or more HDs to keep it (especially during beakin period) from lugging and a safe rule of thumb was to use 1800 as the 'minimum' RPM for the bike.
Not sure if this is 'true' or not. With the 07s they are so 'lean' out of the box I'm not entirely sure how good/bad 1800rpms are for a 'baseline'. Seems there are strong opinions about 2k or higher which seems to be what I recall running on my 03 Heritage Springer with the TC88.
going back to the thread..... and testing it... I can go down to about 52mph in 6th gear with my RPMs right at 1800. However I don't really recommend this as a whole. 65 is generally what I use as a minimun. I'm just above 2000 rpms when going 65 and it is 'ok' with responsiveness at that low rpm. Much better responsiveness from the engine itself once you are doing about 70ish and want to 'gas-n-go'.
I really wouldn't recommend < 65 (no matter what your RPMs say). if you aren't turning enough RPMs you will just be cranking on the throttle to get to the spead you want as it will be sluggish that slow. What gas you are trying to save by shifting into 6th at such a low RPM you will waste when you actually try and go up to say 70 or whatnot.
It is funny ... I typically don't pay as much attention to my Speedometer. I typically watch my tachometer. I know how fast I'm going based on my RPMs and if I want to easy-shift I usually take it up to 3000 rpms and then shift to the next gear which will drop the RPMs down to somewere around 2200-2500 (with the exception of going from 1st to 2nd).
harder to 'gauge' if you don't have the tach and don't have a shield as the wind-noise can overwhelm the stock-setup and you can't hear crap as it is.
Bottom line.... 65 is what I feel is best for the bike overall as a minimum for 6th gear.
  #34
Old 04-18-2007 | 10:36 PM
06BlackWG's Avatar
06BlackWG
I need a tach. But so far at least 60 in 6th unless pushing a lot of wind or pulling a hill. Then I use 5th up to 70 before shifting to 6th. Going down a steep hill I'll use 6th at 50 cause the engine is barely working.
  #35
Old 04-19-2007 | 12:21 AM
ThunderKing's Avatar
ThunderKing
2nd Gear
Nice ride. waiting on 07 to be shipped from Daytona.
How is the VH working for you.
  #36
Old 04-19-2007 | 12:26 AM
ThunderKing
2nd Gear
Default RE: Near home
hey neighbor, Conowingo MD. I know you have had to go to the Union Hotel.
  #37
Old 04-19-2007 | 12:33 AM
voodoodrug's Avatar
voodoodrug
Im shure at least once. Like to take rides to the dam and back
  #38
Old 04-19-2007 | 10:32 AM
TWINCAM96's Avatar
TWINCAM96
65 and up with no problems
nseverett
09-10-2022 03:51 PM
two22
08-17-2009 10:37 PM
BluBob
05-05-2008 03:38 AM
ricks
11-17-2007 09:09 AM
rjw54
06-03-2007 05:14 PM
Quick Reply: What speed in 6th gear?
