Mounting a 09-13 tour pack on a 2004 RK???
I'm looking into getting a tour pack for my 2004 RK. The specific one I like is designed for mounting on an 09-13 bike. How much trouble would it be to adapt this tour pack to the 2-up rack designed for the 97-08 bikes?
Also, there are several aftermarket versions of the tour pack rack for my bike. eBay specials and Mutazu to name a few. Are these comparable in quality to the HD rack? I'd like to get one for less than $200 if I can.
is not the plastic box- it is the mount.
hows about you look into buying the detachable mount kit for your model year.
then put which ever plastic box you get on that?
you can choose HD, aftermarket/ebay....I even saw a BMW buzz by with a pelican case adapted into touring luggage...3 pieces.
Mike
Mike
Mike
Mike
yes, you may have to drill a couple of holes..or not.
but basically you are putting a box on a platform.
If you already have the 09+ tourpak then great.
you'll have to sort out some wiring
black is ground
blue is run
red/yel is brakelight
brown and violet are the turns
mike
black is ground
blue is run
mike
No wiring. I'm not getting one with lights on it.
Neisserj1
12-17-2017 08:40 PM
