Brass Nuts pressed into inner fairing
Old 04-18-2007 | 11:18 AM
rlb5857's Avatar
rlb5857
Default Brass Nuts pressed into inner fairing
Thought I had read somewhere here on the forum something about a repair to the brass pressed in nets in the inner fairing. Can't seem to find where I read about how to repair. Replaced Windshield yesterday and appears that one of my inserts is loose. Someone said it was one of HD worse ideas!!!
Thanks!
Roger
Old 04-18-2007 | 11:25 AM
MntCruiser's Avatar
MntCruiser
Default RE: Brass Nuts pressed into inner fairing
You can get replacements at you dealer. Remove the old fastener. Insert one of the fairing screws into the new barrel with slotted side toward fairing and screw in. Once tight back out the fairing screw.
Old 04-18-2007 | 09:34 PM
harleybuilder's Avatar
harleybuilder
Part number is 16585-96. Once you get the press in nut out, use a 3/8x16 NC bottom/plug tap and tap the inner fairing hole, then just screw the replacement insert in with a wide blade flat blade screw driver. Just replaced all 3 of mine today.
Old 04-18-2007 | 11:48 PM
Peekaboo Bob's Avatar
Peekaboo Bob
ORIGINAL: harleybuilder
Exactly what he said, did mine last summer the same way. Be sure to use the tap.
Old 04-19-2007 | 12:12 AM
05 Ultra's Avatar
05 Ultra
I just used some gel type crazy glue on the old ones. JB weld would work good too. Just don't get any in the threads.
Old 04-19-2007 | 04:31 AM
SeaHag's Avatar
SeaHag
ORIGINAL: 05 Ultra
I did likewise with two part epoxy. I just threaded the bolt even with the end of the insert so that the extra epoxy would ooze out the side instead of up the threaded portion....Once the insert was bottomed out, I unthreaded the bolt and cleaned off the epoxy from its end....That was five years ago and I've never had another problem.
Old 04-19-2007 | 11:24 AM
rlb5857's Avatar
rlb5857
Thanks for all the input, guys!!!
gobblerhuntr
09-20-2011 09:14 AM
Cheese Head
08-30-2010 12:38 AM
ricaroo
04-17-2007 11:50 AM
fryeca
01-07-2007 09:11 PM
jdag
05-10-2006 05:55 PM
Quick Reply: Brass Nuts pressed into inner fairing
