Exhaust Question
You can go to ( www.nightrider.com ) or call them about their FL-ViED-10 it should work
well with your down load, if that is all the work your doing to your Bike. Good Luck.
P.S. ViED which is adjustable at about $120.oo
I purchased my 1st fuelie in '03. Paid a little extra for the Stage 1 download, aircleaner and backplate and a fine set of SE mufflers. From the start the motor always pinged a little. Sometime later I wanted to start adding other goodies and to avoid frequenting my local dealership i purchased a PC USB III. I loaded the Dynojet program for my Stage I bike and noticed right away more power and less ping. learned a little more and added the fuel pump functionality to get rid of all ping.
Moral to the story, IMO - the dealership downloads will usually be lean and the canned programs can be improved. Our motors are air pumps and any time you change the rate of flow through the motor the fuel needs to be adjusted. Head pipes, mufflers, air cleaners all change the rate of air flow...
You may want to consider going with something like the FL-XiED-10.
Also, below is a Overview of EFI options, you may find helpful to you
https://www.hdforums.com/forum/ignit...uning-etc.html
Kelsey
__________________
Cristy
FREE SHIPPING - ORDERS OF $100 OR MORE - LOWER 48 STATES
www.DKCustom.com
Call: 662-252-8828
Text: 662-420-4891
Cristy
www.DKCustom.com
Call: 662-252-8828
Text: 662-420-4891
