Battery tender problem
new battery "last summer" does not equal "good battery"
check the fuse in your tender cable ( most tender "pigtails" have -and should have a fuse in them)
then checks are:
pull battery ( neg cable first- no sparks that way...and neg cable last on install)
charge battery with charger 2 to 3 amp charge rate for 12 to 20 hours)- then load test at dealer or autozone ( free)
check your cables are clean and tight ( both ends)
if all ok, reinstall and try again...if still flashing red then the tender could be bad.
mike
then checks are:
mike
Sometimes my tender gets off to a bad start and the red light flashes. I just unplug the power plug and reconnect, almost always get a normal indication in an hour or so. I have also cleaned the pig tail connections with Q tips and Brasso. An amazing amount of black gunk came out of each plug socket. Since cleaning the plugs, I almost always go to the green maintain light in a short time.
[QUOTE=btsom;13628553]Sometimes my tender gets off to a bad start and the red light flashes. I just unplug the power plug and reconnect, almost always get a normal indication in an hour or so. I have also cleaned the pig tail connections with Q tips and Brasso. An amazing amount of black gunk came out of each plug socket. Since cleaning the plugs, I almost always go to the green maintain light in a short ti
Same solution,Tender has to have clean contacts to work properly
I broke one of the connectors putting everything back together one day. the next day plugged in the tender and got the same thing you did! had to buy one of these http://www.batterytender.com/Accesso...l-Harness.html
