solar powered battery tender
I know this is an older thread
But what was the verdict on this topic? Did the Harbor Freight solar panel mentioned for under $20 do the job? I'm interested in anyone's advice on this because my bike will sit outside for about a month at a time in a parking lot, so I need a solar battery tender solution.
I bought the one in the attachment below. I used is for when my Harkey was in my enclosed trailer for extended periods of time. I mounted the panel to the roof and ran the cable inside. I have dual GPS trackers that will run the battery down in 4 days.i know the solar charger works because, when the Harley is in the trailer for extended periods of time connected to the solar charger, the battery stayed charged.
Oh yeah, but it needs sunlight on the panel...
My previous post on this:
https://www.hdforums.com/forum/off-t...ed-harley.html
I use one of these on my truck since it sits most of the year. It starts right up even if it sits for months. Nothing to complain about. I just set it on the dashboard.
Solar cells can be used in many fields, solar street lights, energy-saving lamps, garden lights, to find the right objects, because there are many problems, such as the length of time, brightness, etc.
Received 1,939 Likes
Keep in mind there is an absolute difference between SELF DISCHARGE in an Li battery and the constant LOW DRAIN of various keep alive memories, clocks, and alarms. Li batteries have a long SHELF LIFE when NOT being drained by various accessories. With constant drain, they will die just like any other battery and may not recover below a certain discharge point.
mikedero
10-21-2010 04:50 PM
