oil temp. gauge
RE: oil temp. gauge
I have an 07 Ultra and had the Dealer install the oil gauge in the fairing, I also have an oil cooler. They have tried 3 times to make the gauge go over 110 degrees. The gauge has power, they have tried installing before the oil cooler and after the oil cooler.
This is one of the larger Dealer in Houston!
RE: oil temp. gauge
ORIGINAL: Macadoo
By the way, find another dealer. Obviuosly this one doesn't know chit!
RE: oil temp. gauge
ORIGINAL: Timex
I am needing some help with an oil temp. gauge on myFLH. I have been through 3 sending units, and still only had a signal from the first one, lasting about 5 weeks, till it quit. Do these sending units go bad? I'm not sure. Help .....
Now, ride the bike and let it warm up a bit. With the sender wires connected to the sender, not the gauge, put an ohmmeter on the sender and ground wire going to the sender. As the bike cools you can watch the meter increase in resistance literally every few seconds. If it does this, the sender may be okay. The problem is that HD doesn't provide diagnostic info on the correct values for the sender, so even if it's moving it would be hard to tell whether the values you're seeing are correct.
If you have the McEwan kit, the sender is grounded at the oil pan. Thus, if you used Teflon tape or other sealant it may not be making proper ground, which would make the gauge no respond. The HD sender has its own ground wire, which makes this irrelevant.
RE: oil temp. gauge
ORIGINAL: Macadoo
RE: oil temp. gauge
Thank you all for your reply's. The sending unit is in the pan, no teflon tape, and is a McEwan gauge. Roger sent me a new complete set-up to try. Nothing working on the second gauge and 3rd sender. I am sure the wiring is correct, as it worked the first time for me, wired up a second time on the new gauge the same way as the first.
