Yaffe 12" Monkey Bar Install Help
I did not extend wires when I put them on Streetglide. I just relocated the plugs to under the radio in the fairing. I went with a +6 clutch and a +4 brake line. I could have gotten away with a +4 clutch cable. I used Mangum sterling chromite cable and line. I would suggest using a SE TBW. I have used that several times since. Pull TBW first then remaining wires.
On my 07 SG.. no need to extend wires.. 6" upper brake cable & clutch cables and was good. Did replace throttle & ides cables too .. Tedious but well worth doing the work yourself: Service manual was the best thing I bought for my SG.
