Cam and Crank sensor replacement
2000 RK going through and replacing sensors and coil. Bike ran good then no power then good, no power. Kept breaking down every time I took it out.
I converted the MM efi to carb. Have started it and sounds good. Used All stock wiring harness and cv carb. Stock ignition. All the parts that would have came with it if it was a carb bike from Harley.
Thought while it was winter time and on a lift would also eliminate 3 more things that could have made it run off and on.
Crank , cam sensor and thought I would replace coil.
How do you get the female electrical connection apart to expose the 2 or 3 wires to pull through the sleeve.
I have a manual, but don't understand.
It is the 2 connectors that are on the end of the cam and crank sensor wires. How it comes apart
I don't like taking things to mechanics. want to figure things out myself...
Straightleg
Straightleg
I bought the Daytona Twin Tech ignition module, you no longer need the Camshaft position sensor with this adjustable ignition module, I highly reccomend getting it.
It is easy to put in, plug and play, and allows you to adjust your timing plus has a adjustable rev limiter, it works great.
If you have good performance then bad then good.. Make sure the motor ain't sumping.. The sensors you list typically will cause starting issues if going out but won't cause random power issues.. One sensor that can cause this issue is the Map Sensor.. They can randomly fail and heal.. When bad they set the manifold pressure to the equivalent of wide open throttle, which causes the ignition module to run the slowest timing curve. It will make the bike feel sluggish and can also effect the idle.
You are right. We shouldn't be telling you what is possibly wrong..
The process to disassemble the connectors is in appendix B of the service manual..
Add:
The description is pretty good.. Use a magnifying glass if having trouble identifying parts of the connector.. You may end up braking the housing the holds the pins in but they are not too expensive to replace..
Add:
Add:
Add:
Thanks
SL
Thanks replaced that just recently.
SL
Andy2166
06-15-2018 06:38 AM
marnold@aisg-online.com
09-04-2016 10:38 PM
