Will a 96/103 from an '07-08 bolt up in a 03 ultra classic. Not sure if they will bolt the same or if it's different. A buddy lost inner cam bearings and trashed the motor.
Same thing just happened to my motor on my 07 FLHX.
It's not just the bolt pattern, the earlier bike uses external oil pipes between the oil tank and pump, whereas the later engine doesn't use pipes, but internal oilways. The early trans and later engine are just not compatible with each other.
