Might want to put a wrench on yours
Well, the left passenger floorboard assy fell off now. I didn't lose this one but the bolt was a little loose and when i flipped the board down, it sheared the "grade 8" bolt. After the last one, I added checking these fasteners every 10K to my service list. I guess it's going on the 5K service list now.
I'm assuming that even with blue loctite, those bolts are vibrating loose causing them to shear off. I'm using red loctite this time.
I don't understand why they use grade 8 bolts on these things. A few years ago I lost the passenger floorboard assy with a kury adjustable passenger peg. The grade 8 bolt sheared off. Grade 8 are made to not stretch not for shear resistance. I replaced the bolts with grade 5 and never had a problem again.
I just put a SE Clutch Spring on my bike last month... when removing the Left side front & rear footboard I found the bottom bolt on the rear board was out about 7/16"... The top bolt was still good and tight... I then checked the right rear footboard and it was the same way,,, loose... My bike has 18k miles on it.
Received 2,530 Likes
