2006 Road King regulator test
I'm having charging issues with my 2006 Road King Classic. I've done the battery test, and it is fine. I'm trying to do the regulator and stator test, but there's one thing none of the threads, videos, etc I've looked at explains. How do I unplug the regulator wiring so I can test the pins? I can see where the three wires plug into the primary casing to travel to the stator. Do I just pull really hard to disconnect, or am I missing a retainer clip or something somewhere? I know it's probably a really dumb question and I'm just missing something easy, I just don't want to start pulling and end up with a bigger issue than I already have.
Hi from the UK and welcome to HDF. You may be able to answer your question by looking at one of the on-line parts websites, like this one. That should confirm where the plug is and give you a better chance of getting it apart (as Mike suggests, it does indeed seem to be at the regulator)! You may also find the Stickies on the charging system in our Tech Electrical section helpful.
