2010 Road King Serious Electrical Problems
Old 01-21-2015 | 11:38 AM
mkguitar's Avatar
mkguitar
sounds like the abs is stuck in the self-initialization test, where the abs tests system valves, solenoids. ( this may stop if you apply the brake)
ghost in the machine
are you seeing any trouble codes?
abs light or other dummy lights?
are there any added electrical/electronics to the bike?
the high beam indicator with low beam- is a real mystery as that circuit is hardwired.
mike
Old 01-21-2015 | 12:16 PM
SanityClaws's Avatar
SanityClaws
6th Gear
Have not seen any Trouble Codes....haven't tried to apply brakes, but that is an idea. Will try it. I have a Cert. Harley Mechanic that wants to take a look but I'll need to get it to them. I'm beginning to run out of ideas.
But thanks.
Old 02-07-2015 | 09:27 PM
SanityClaws
6th Gear
Same ol', same ol'......applied brakes....front & rear......no changes. unplugged & replugged connections.....no changes.
On a side note, I just installed a trailer hitch on my 4-wheeled vehicle....& ordered & got the electrical connections OEM for the vehicle. Connected them today.........& no lights light up on the trailer. My bad luck continues. No power to the 4-way light connector. Re-checked all connections...still nothing.
Old 02-07-2015 | 10:04 PM
mkguitar's Avatar
mkguitar
You again!
hey just occurs to me that if the filaments in the headlight touch, that would illuminate the high beam indicator with the low beam...pull that bulb out and see if it goes to normal.
mike
Old 02-14-2015 | 03:46 AM
69onmy09dyna's Avatar
69onmy09dyna
In my 25+ years of twisting wrenches I have found 4 things that cause weird problems like this. Aftermarket accessories is one. The other 3 are grounds grounds grounds. This is even more so with electronics. Anything more than a 1 volt drop across a ground will deal you fits. Also as fuelish said the most complex problems usually require the simplest solutions.
Old 02-14-2015 | 08:12 AM
GTK's Avatar
GTK
Talking Problem solved
Well SanityClaws,I hope you get this problem sorted out.But on a lighter note,you could always ride one of the reindeer.
Old 03-30-2015 | 11:37 PM
SanityClaws
6th Gear
Default Still No Help
Got the King to a certified Harley mechanic. Unable to trace the source of the short (if there is one). No codes or anything else displayed on the LCD speedometer. It does not illuminate at all when the battery is hooked up. The ABS Module is the culprit with the whirring sound. The only time it stops is when you pull the fuse, the main fuse or remove the hot lead of the battery.
Looks like I'll just be parking her in my storage until I save enough cash to take her to the HD dealer.
Really disappointed. Only other solution is to check when my Extended Warranty runs out & if that module is covered under it.
Dock
09-22-2016 04:39 PM
Badboy01
08-31-2015 01:15 PM
nashvegasmatt
09-12-2014 06:42 PM
tc
EVO
13
08-16-2011 09:21 PM
kd4tsc
09-06-2009 02:48 AM
Quick Reply: 2010 Road King Serious Electrical Problems
