Sputters on WOT, erratic idle, running like crap...
When I started it earlier and just blipped the throttle you could here it was not running right before I even rode. This was after the PC was off. I have put the PC back on and started it an blipped the throttle and it is not sounding like it's firing on one cylinder. We'll see what happens when I leave to go home.
Fingers crossed.
Fingers crossed.
Apparently you didn't hear about my last dealer experience. I'll leave it at that.
So whatever it was it is fixed. A lsit of what I did was
1) Remove the PC and still had the problem.
2)Replace the plugs still had the problem
3)Reroute all wiring under my seat (which I recently changed) seemed to help a little.
4)Unplug and reseat plug wires on both ends on both plugs
5)unplug and reseat the fuel connection on the tank
I am not sure if it was one thing or a combo of several but I rode home without issue so I'm a happy camper. I checked codes even though the CEL did not come on and I only had the two codes for turn signal voltage as I have the CD LED signals which have always worked perfect with the load equalizer.
Your thoughts?
Your thoughts?
