Got a 2004 RKC and wanna take off that heavy duty stock front rim . What would it take to swap it (bearings/hub/axle) and put on the 19" enforcer on it ? Also could I go single side brake setup ?
You need a 08 & newer axle & spacers for any newer wheel, as the fork lowers are the same from 00-13. If you plan on using the Enforcer wheel you will need to swap out your calipers for 08-up brembo calipers, which is a very good upgrade.
The reason for the caliper swap is that the rotors that come with the enforcer are 11.8" whereas your stock rotors are 11.5" and the enforcer rotors are not available in 11.5" and have a different bolt pattern to mount them to the wheel. Also check and see if the wheel has an ABS bearing as if it does you will need to swap that out for a non abs bearing. The ABS bearing is wider which affects the spacing.
