inner fairing
inner fairing
I checked the fairing brackets to be sure they were alright, when I went to reassemble the fairing and torque the 7 screws (20 inch pounds)one of them (Windshield right side) will not tighten all the way the screw spins, I think the brass insert is spinning in the inner fairing. Is there a fix?maybe an epoxy?
Thanks
Rick
Thanks
Rick
RE: inner fairing
I think I found an answer after doing a search...
Go to your'e dealer and get part #16585-96 fairing insert. These thread in instead of push in. When you get one you will notice there is a slot in one end. Don't try winding it in with a screwdriver as you will snap the end off. The end with the slot is for starting in the fairing, then use one of your'e fairing screws with a nut on it for a spacer so you don't bottom it on the inner fairing when you wind it in. This is a simple, excellent repair and is what should have been installed right from the factory
