Any 2 wheeled gliders change to 30 tooth front sprocket
Old 01-02-2015 | 02:01 PM
SmittyFXDL's Avatar
SmittyFXDL
Default Any 2 wheeled gliders change to 30 tooth front sprocket
Has anyone on a 2 wheeled glide changed their front sprocket to a 30 tooth? I read the thread on changing on a trike and wanted to know if 2 wheelers still needed to change the belt.
Also, can you share what special tools where needed and any other tips for such a project. TIA
Old 01-02-2015 | 03:16 PM
SGNEWB's Avatar
SGNEWB
I ordered my 30T sprocket and new belt yesterday and anxiously awaiting them to arrive to install. I will report back when finished. FWIW I ordered the sprocket for a trike and a 1" wide 139 tooth belt.
Old 01-02-2015 | 03:29 PM
SmittyFXDL's Avatar
SmittyFXDL
what did that cost, if you dont mind my asking? Did you have to order special tools as well?
Old 01-02-2015 | 03:54 PM
crimson13's Avatar
crimson13
Which belt did you order ?
There has been problems with the falcon belts breaking.
Old 01-02-2015 | 04:00 PM
crimson13's Avatar
crimson13
The sprocket is 60 bucks from kutter hd. You will need a 21/4 socket that comes with a pilot bushing ,and a transmission sprocket lock tool.
I used the stock belt and just slotted the swingarm 3/16s to allow for adjustment, I did this on a 2013 street glide cheap torque mod . There have been numerous problems with some of the 139t belts. I believe the gates poly belt will the one to get they cost around 155.00
Old 01-02-2015 | 07:37 PM
SGNEWB's Avatar
SGNEWB
The whole deal will cost me about $200. Bought the belt (Drag Specialities) off ebay for $129 free shipping and the sprocket from Surdyke for ~$60. I didn't feel really feel comfortable slotting my swingarm.
Old 01-02-2015 | 08:50 PM
jack6hd's Avatar
jack6hd
You can use the OEM belt if you elongate the slots in your swing arm. It allows the wheel further back.
Old 01-02-2015 | 08:52 PM
DBLX's Avatar
DBLX
And what was the performance result? Worth it?
Old 01-02-2015 | 10:09 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
aother option is the evo industries clutch basket dive gear, parts cost more but lots easier to install.
Old 01-02-2015 | 11:40 PM
mike5511's Avatar
mike5511
I put the 68T on the rear and have a 31T to go on the front, just never have got around to doing it. Let's me use the same belt and will let the rear wheel slip back to about it where it was when new.
Quick Reply: Any 2 wheeled gliders change to 30 tooth front sprocket
