Passenger-Footboard for 2012 FLHP
I want to add a passenger-footboard to my 2012 FLHP (and, of course, a passenger seat, the Mustang recessed passenger seat, as offered for the FLHP with original police-seat).
I wonder if I can use the "old" footboards/supports (no.52719-93B), which were used with the civilian models until 2009, or if I must buy the new supports (52719-10) which were mounted at the civilian models from 2010 up to now. Some people say that the old supports only fit up to 2009 and in 2010 the mounting-base at the frame was changed so that only the new support fit - some say the opposite.
What is right, what is wrong?
In 2009 the MoCo changed the frame design including the rider footboard bracket. Then in 2010 they changed out the passenger footboard bracket.The change went from an inverted teardrop shaped mounting flange on the bracket that used a single 3/8-16 SHCS and a 5/16" extruded tit that located into an unused 3/8-16 tapped hole on the frame for anti-rotation purposes. In 2010 the passenger bracket mounting flange was changed to an elongated flange that had a single hole which took the 3/8-16 mounting bolt and an elongated slot that accepted a 5/16-18 SHCS so that the newer design was held on by 2 bolts as opposed to a single bolt on earlier models. You need to go with the newer bracket.
But it could be possible that the old supports also fit in 2010 and up. That´s why I am asking.
Bingee
06-28-2013 02:41 PM
