Is this "O" Ring needed?
Old 01-01-2015, 11:43 AM
Sandcrab's Avatar
Sandcrab
Sandcrab is offline
Default Is this "O" Ring needed?
I bought the Screaming Eagle Cam support Plate/w oil pump P/N 25282-11. The instructions say to install an "O" ring which was included in the box, on the splined cam on Screaming Eagle Cams. I bought Woods Cams, but just wanted to make sure I don't need to install the "O" ring on the Woods cam installed in the SE cam support plate.
Old 01-01-2015, 12:06 PM
Sandcrab's Avatar
Sandcrab
Sandcrab is offline
Default Is this required?
Here is a picture of the instructions and the "O" ring
Old 01-01-2015, 01:21 PM
sanman4ever's Avatar
sanman4ever
sanman4ever is offline
I heard you can only use Harley SE cams with that plate......
Old 01-01-2015, 02:16 PM
Sandcrab's Avatar
Sandcrab
Sandcrab is offline
Default Oh sh..
Are you sure, I hope not, where did you hear that???
Old 01-01-2015, 02:18 PM
sanman4ever
I'm sorry, I couldn't resist. Call Fuel Moto would be my advice unless someone here knows for sure.
Old 01-01-2015, 03:56 PM
Tinman265's Avatar
Tinman265
Tinman265 is offline
I used it and I installed Andrews cams. Sits at the bottom of the splines.
Old 01-01-2015, 04:08 PM
Sandcrab's Avatar
Sandcrab
Sandcrab is offline
Default Clarification
I also installed it, and then noticed the wording. Here is the exact wording: "When installing Screamin Eagle camshaft kits, install the O-ring included in this kit over the splined shaft of the rear camshaft as shown in Figure 1."
So you have the SE cam support plate and Andrews cams and installed the O ring. How many miles since doing it if you don't mind my asking.
Old 01-01-2015, 04:19 PM
Tinman265's Avatar
Tinman265
I have only started the bike since installation. Finished it up last Friday. Sounds like a hot rod with the andrews 57h cams. Then I took it back apart for a painted inner faring and chrome forks....
Old 01-01-2015, 04:40 PM
Sandcrab's Avatar
Sandcrab
Sandcrab is offline
Default ***** on a bull
I just keep looking at that O ring on a rotating part, and can't but wonder how long will it last and then shred pieces into the bottom of the cam cover. Just not convinced it does anything. Here is where I am on my build.
Old 01-01-2015, 05:52 PM
Tinman265's Avatar
Tinman265
I don't know what it does but it is sandwiched between the cam and gear and will not drop out of there.
Quick Reply: Is this "O" Ring needed?
