detachable two-up tour-pak rack stability
I know a lot more folks are going with the detachable tour-pak setup. I have my tour-pak off right now and am looking at this option, as well. I have read back through the posts and found a couple of folks who said it wasn't very stable, and a couple of folks who said it was rock solid. So, for those of you who are currently using the detachable tour-pak rack,what are your obversations on stability, movement/play, vibrations, etc...? Thanks in advance.
RE: detachable two-up tour-pak rack stability
Are you askin if the bike is stable without tour-pak on? If you are then I would say that the bike is super stable and handles more like a sport bike than any other style Harley I've had except Sportsters(4-speed Shovels, Fatboy, Springer etc.). It's a great mod and will make you feel like you have 2 bikes in one.[sm=goodidea.gif]
I'm using the detachable tour-pak setup. Wife and ride all the time have experienced no problems with it. When you install it just make sure everything is tightened down and check it from time to time like any other part of your bike. I have mine set back for the wife to get comfortable.
The two up detachable tour rack if installed per instructions is rock solid.As with any thing else,the mounting rubber points might have to be replaced after wear occurs.I did a lot of research on this and talked to people who had the removable rack installed and if they had any problems over time.
