For road king owners with cruise. Is the on/off switch a toggle type? As in 2 position stays switched on or off? Or is it a momentary 3 position with the switch usually in the middle and pushes one way to on and the other to off?
On my 2012 RK, there are 2 switches to operate the cruise. The one on the left grip is a 2 position cruise on/off. The one on the right is a spring loaded momentary switch for speed set/resume + is normally in the ctr position.
If the control that you have has the set/resume you could just use that then use one of your nacelle switches to turn the cruise on/off. Or, just wire the cruise to be permanently on and not worry about a switch if both are already used.
Originally Posted by Jimdgreat1
I'm thinking about using the accessory switch for on/off. Didn't think about wiring as always on. That's a good idea. Thanks!
Yeah you are just simulating what Glides do...works for them. Their Cruise comes with Right Side control only with a lighted "Cruise" on-off rocker switch to mount in the "Inner Fairing Cap"
Thanks everyone. The two position is what i thought.
Found a right hand control with set/reset and audio control. Thought I might be able to convert the audio switch to on/off. Won't work.
You might be able to use that switch with a latching relay. Apply power once...Latched ON. Apply power again...OFF
