Make me smart on the benefits of dyno-tuning an older bike
So I have my 04 RK FLHRI at the dealer getting some winter work done. I'm having them do the SE cam tensioner upgrade with the oil pump, SE204 cams (because they're free), new lifters, SE adjustable pushrods, and SE tuner/dyno-tune. The bike already has a K&N style air filter (which I don't think it had been tuned for) and I installed MGS True-Duals right before I took it in for the work.
I can understand why a tuner and dyno-tune would benefit a newer bike, since some of the emmissions features can be turned off and they have O2 sensors.
What exactly is the tuner going to do for my bike? I know they'll adjust the fuel to fatten it up, but is there anything else they're going to do? Would I be better off saving my money and just getting a fuel-pack or something with a canned tune based on my mods?
You're going to get several who say yes dyno and an equal no. that say no, don't dyno. Personally, unless you have a really radical build and/or intend to race your bike at the track, I think the dyno is a waste of money. On my 2000 Heritage (A/C, pipes and cam) I just had the carb jetted and it runs great and has plenty of power. On my 13 RGU I'm just running the AC and pipes with the fuel pak and it also runs great. Now let the flaming start!
I am not saying these new computerized bikes don't need a dyno tune in certain instances, but I do think a lot of the guys just like to make it known that they had their bike on the dyno as they hand you a copy of their print out sheet. As they puff up their chest.
My brother has a 2014 Ducati with all the bells and whistles. He has made numerous changes in air cleaner, gearing, hotter spark, and a few things I don't really understand. But he breaks out his lap top, has a program to change his tune, makes those changes and test rides it to see if it's what he wants.
If you are racing your bike/car or whatever, dyno tune is almost a necessity, but if you're just cruising around enjoying the day, it's not needed. Those with deep pockets will want it because they feel it gives them something over the other guy. I guess I'm always going to be old school, give me a carb, a screw driver, some jets, check the timing and I'm good to go.
Doesn't the I at the end of the OPs model (FLHRI) signify fuel injection? Would that be the MM system or Delphi in 2004?
Dyno tune isn't just for race bikes - every motor is different and only by tweaking and measuring at each rpm will you get the smoothest most efficient running motor. It's all about finding a dyno operator that knows what they are doing and willing to spend the time to do it right. More power across the board is the byproduct of optimizing gas and ignition at each level, not just better peak numbers. It doesn't matter how old the bike is.
Have had both, Canned map on a PC V, and a dyno tune, first by a dealer, and second my an independent. The dealer's tech ran it on their dyno, and it didn't run right. Had a miss at 2200 rpms that they couldn't tune out. The dealers dyno tech recommended putting the Power Commander V on it with a canned map. The bike ran great, better than the so called dyno tune from the dealer.
Moved to another state, dealers didn't want to service bike with piggy-back type tuner. Had moved to an area that had one of the premier tuners in the SW, so I thought I would go with the TTS Master tune and his tune. Not only does he tune it, he lets you watch every step of the way. You can actually see what is happening, and how things are effected. They also take time....usually a minimum of 3-4 hrs. The bike had never ran smoother, cooler, has more hp and torque. Also gets better fuel mileage.
A dyno tune is only as good as the operator doing it. Period!!! My first go round, the tech had very little knowledge of the equipment that he was using, my fault, assumed that a Harley dealer would want to have the best tuner.
Second time...had a very experienced, very sought out tuner do it. The difference is like night and day, you wouldn't even know it was the same bike. Both dyno tuned, but with different results.
The Power Commander was a good alternative for me, never let me down and the bike ran ok.
If you are changing cams and you want the full effect, get a dyno tune, from a competent tuner, it costs money but done right you wont regret it.
Having said that, with a good dyno tune operator you will get the best running bike for your mods, whether it be FI or carb.
I believe with a carb bike and a good dyno tune operator, the dyno tune will be a better investment than with FI.
If you have an FI bike, I believe when you combine a good tuner (I love my PowerVision), with a map from a good tuner shop (like DynoJet or FuelMoto), it will be a better investment than a dyno tune.
I feel your bike will run really well, not perfect like a good dyno tune, but certainly good enough. Throw in a few auto tune sessions and the map gets dialed in to your VE tables. I doubt most would notice the difference between this route and a good dyno tune.
A plus, you'll be able to readjust the tune for any future mods, without the need to shell out for another dyno tune.
Just my 2 cents.....
I was "sold" on dyno tuning back in the 60s at college auto shop with a dyno. No matter how good ya are with a screwdriver and box of jets, ya won't do as good as a guy who knows what he is doing with a dyno. With fuel injection it just gets worse... With cams in your bike the only way to get it tuned properly is on a dyno. Of course if the guy doing it is an idiot, all bets are off. Oh and Auto tune basic is off the table on a '04.
PS your statement "I can understand why a tuner and dyno-tune would benefit a newer bike, since some of the emmissions features can be turned off and they have O2 sensors." shows ya need to bone up.
