View Poll Results: Go for the higher lift or stay low and still happy
Go higher lift
43.48%
Keep low and just as happy
13
56.52%
Voters: 23. You may not vote on this poll
Andrews 26 comments (bumped)
So here in the Orlando area we only have a couple of indy shops that are worth anything. The one that I trust and use (been in business for 25+ years) is telling me if I want a good cam upgrade I will be happy with the Andrews 26.
I mostly ride my street glide on the freeway between 2700-3000 rpm solo but do like to "get on it" every once in a while with friends, on ramps, stop lights, etc. Occasionally my wife and I like to go for rides through the back roads here in Florida and put quite a few miles on the bike.
I was looking at the 222 or even the 555.
His concern is lift. He doesn't like going that high on the stock heads. He admits to being old school and if it ain't broke don't fix it but he works on a lot of the bike cops motorcycles around here and that is what he puts in theirs and he says they are very happy.
His thought is that if I want a reliable bike with more get up an go for a bagger w/out screwing up any resemblance of fuel economy then I should stay with a lower lift.
I told him I was a little concerned that I would want more a little later. His deal was that if I wanted to do headwork or something else later and if that cam wasn't working out for me then he would swap the cam at no charge while doing the rest of the work. That seems okay to me.
My concern is that I don't see anyone with newer bikes using this cam on any forums I'm reading. These are mostly older bikes TC88 or up to the 95"er.
Is he missing the boat by being a little over cautious and "old school"? Should I tell him not to worry about the lift and just install a bigger/newer cam?
I would feel better if I could just hear from people that are using this cam in their newer bikes and what their thoughts on it are.
Current tune is 80 HP and 100 TQ Stage 1.
Thanks for the input, I want to get this cam upgraded next week.
__________________
__________________
The 26's work best with the slight bump in compression that comes with the 95" big bore. Thats what my bike came with (with 203 cams,) and the 26's are just an increase in what the 203's offered. I'm very happy with them. I don't pull high revs typically but once in awhile I'll pull a freeway ramp through the gears just to see how things are running down there and the cam pulls strong into the mid 5500 range ( I've never banged the rev limiter.)
Reliable? I installed them Jan '11 at 81,000 miles and the bike just turned 147,000 last month. I'm thrilled with my choice of the 26's.
on the 103?
The 26 will work fine but, why not get a bit more lift? The later style valvetrain can handle it with no problem. Andrews 48 or 57 would work great. If I recall correctly, the 57 is pretty much the same profile as the 26 with more lift. Get it tuned and you will get good fuel mileage.
I use the 48's and have no complaints.
on the 103?
Received 75,528 Likes
__________________
__________________
Get the cam you want.
I doubt you will have any regrets.
Have your wrench do the work.
He may even learn something from it or your change in thought.
After all it is your bike, not his right?
Im sure it will be fine. Plus with his upgrade he will save me about $420 totally installed over the woods cam and install kit.
