View Poll Results: Go for the higher lift or stay low and still happy
Go higher lift
43.48%
Keep low and just as happy
13
56.52%
Voters: 23. You may not vote on this poll
Andrews 26 comments (bumped)
Received 75,536 Likes
Probably hundreds of threads on cams.
LOTS of reading if you want.
I went with a fairly low lift cam too for my 96 as I did not want to put too much stress on the valve train.
The cam I am running now was recommended to me by Frank Drago and another indy shop up the road from where I live.
If you really want to compare characteristics though, look here.
It will allow you to compare 3 cams at once and about all cams that have been.
Check it out. http://bigboyzheadporting.com/tccams.htm
Myself I prefer a low end cam, one that comes on out of the box basically but will still keep climbing.
This forum is great but easy to get overwhelmed. Haha
Thanks again.
Andrews 48 IMHO. Made specifically for your application.
https://www.google.com/url?sa=t&rct=...XK0xvK-8TkZ5qw
I read a lot of cam threads too, and understand your confusion. Many recommend they cam they themselves use, but the real deciding point should be a realistic range of operating parameters given how you ride. I don't know about how the rest of you guys ride, but I rarely see north of 4K. I have the 21's myself, and they pull hard right off the line at 1800. Even with my small displacement 5 speed bike, at 75mph I'm still turning less than 3300, and the cams are good to 4800. I'm not trying to endorse the 21's, or the 26's or any other cam for that matter. I'm just saying a torque cam with lower lift is good on the street. It also saves on stiffer valvesprings that are sometimes required with high lift.
He did say that if I felt the need for more later and wanted head work and to go bigger he would swap the cam out at no charge because he can just use it on another bike. That's how much he likes and uses them. He also said he doubts I will want more later. We shall see...once the power bug hits you its all downhill from there. He is confident and I guess I should be too. He has been in business for a long time for a reason.
