2012 street glide battery dead???????????
an alarm or radio memory will draw power.
the most common drain is electrons flowing between the poles on the battery case through dirt and moisture
Many of us replace with big krank batteries by east penn/ deka.
check amazon or ebay, about $100- see if you can bundle with a battery tender.
once discharged a battery will only recharge to about 60% of it's previous capacity...so even if yours charges up it is on it;s way out. You may as well choose to replace it on your terms rather than roadside.
Mike
Mike
I use a $25 Schumacher tender available at Walmart. Works like a champ and includes all pigtails needed. Will even match up to the dealer tender pigtail if your dealer installed one on that 2012.
I went with the Big Crank battery. The HD battery is OK, just way overpriced for what you get.
You didn't list what your other bikes were, or if your 2012 Street Glide has the security system.
Security system, and the audio system will cause a small constant draw on the battery. This is the same as any other vehicle (car, truck, or bike).
If your other bikes didn't have those features, that might be the difference.
You didn't mention how long the bike had been sitting without running?
They should be able to sit for at least a month without issues, but that is hard on the battery.
If your battery goes dead in just a week or two, then you probably have a weak battery or an unusual current draw.
Sitting any longer than a few days, its always best to keep it plugged into a battery tender (or other "smart" charger).
I have a '12 SG. sits for 3 or 4 weeks (not very often though) between starts and have never had a problem.
I'm with some of the above, you didn't mention whether you had security or not. or maybe some other mods. I'm sure you didn't leave the ignition switch on. so for sure a good question. If no other draws on the battery, i would have to go with just a battery that was weak and sat for a while.
Mech I like at local HD told me HD started sourcing btry's from diff supplier in 12 and that they had replaced almost every 12 that had came in around 2yr mark. Mine was slow starting and just out of warranty so I went $99 Big Crank vs $200+ for another HD one.
As for the tender my brothers 12 is (3 weeks newer than mine) always plugged in and his left him stranded at work after it slow started in the morn when he left. Shouldn't have ridden once it slow cranked but like many he gambled with a weak btry and lost.
Clif
Clif
I've had a btry go 8yrs and 2yrs 1mo and have never owned or used a tender. I'd say def a good idea if your a owner not a rider. If my bike sits 2 weeks it's rare but if yours sits for a month or months like some then good investment for sure.
Clif
