SE ventilator air cleaner
Well it does have a limited life. I had mine on my SG for nearly 2 years. It should have been cleaned by the service department when I had my 1K,5K, 10K, etc. services done. At least I hope they did. On my 25K service they wanted to replace that paper filter, but didn't have one in stock. I just went ahead and had them order the K&N filter instead. it wasn't that much more and will last forever...
I will add that the guy that was doing that 25K service washed the filter out with water and ??? before he put it back on. I only remember that because I remember him saying something about hanging it in front of a fan to dry before he put it back on.
And that is the I always looked at it too.
But it says right on the filter element box, that this one can be washed in mild soap & water.
Perhaps this isn't just your standard "paper" filter?
As others have mentioned though, it probably does have a limit to how many times you can wash it and still hold up.
And you do not oil the standard ventilator filter (says that on the filter too).
I have washed mine twice so far and it is still holding up.
