Caliper mounted lights?
Hello all, so I've already ridden 300 miles on the new RG. Put the 12" Windvest on it big improvement, no buffeting now. I'm 6'.
On to the question I'm looking for more light. Used to the lights turning and the daymaker has a definate cut off point. There bright but.......So I'm thinking of mounting Driving lights to the fender mounts or the Caliper mounts. Anyone know anything besides e goodies? They are really expensive I know you pay for what you get.
Sorry for the rant. Here's a quick shot
Love the new Project Rushmore Suspension
I posted my path to phenomenal lighting on another post that is titled something about 'selling my Daymaker'....look over on it, nothing fancy, nothing expensive, just 330 watts of light going out to the front if you want it all for less than fifty bux...maybe around forty bux, actually...
You may get the lights to turn on slow speed turns, i.e. going around a corner at a street intersection, but for curves on the road, your lights don't actually turn in the direction that you want to go. When you lean your bike into a curve, you are actually pulling the handle bars in the opposite direction so you headlight is actually pointing a slight bit to the opposite direction of the curve you are following. Your RG gives you better lighting straight ahead than a SG would. Additional auxiliary lights don't throw enough forward light as your main headlights do. Check you state regs on how many forward lights you can actually have on the bike. Most states allow only 4.
Mark
........ your lights don't actually turn in the direction that you want to go. When you lean your bike into a curve, you are actually pulling the handle bars in the opposite direction so you headlight is actually pointing a slight bit to the opposite direction of the curve you are following.
