Broke a the Rear finder light wire housing plug
Old 11-30-2014 | 09:52 PM
raksasas's Avatar
raksasas
Default Broke a the Rear finder light wire housing plug
I am trying to find the wire housing plug part number (pins and plug) for the rear fender, running light (?) on an 13 ultra classic. The part that plugs into the spot behind the break light. I found a couple of ebay but not sure if they are the right match.
Thanks.
Old 11-30-2014 | 10:45 PM
Toofat's Avatar
Toofat
Plug part# is 73153-96BK and the pins part#'s are 73191-96. When you need to look up a part# use Ronnie's HD.
http://partsfinder.onlinemicrofiche.....asp?make=hdmc
Old 11-30-2014 | 11:49 PM
mkguitar's Avatar
mkguitar
fender tip light?
If you broke the plastic plug...can you just put the wires over the pins on the board?
A squirt of silicone RTV will keep them from vibrating off.
both of the wires from the tip light are black, they go on pins 1 and 3 ( pin 2 is for optional brake light function.
I don't think the 2 black wires are polarized but they may be...try it one way and if they do not work when tested, swap them.
Mike
Old 12-01-2014 | 12:18 AM
raksasas's Avatar
raksasas
Thanks man. I sure will.
RED_5
05-22-2020 04:05 PM
sickboy75
08-14-2014 01:06 PM
pipedog
EVO
05-07-2013 02:15 PM
MIBPreacher
06-11-2012 11:57 AM
scarab75
02-15-2008 10:34 PM
Quick Reply: Broke a the Rear finder light wire housing plug
