Change lifters or don't
Old 11-30-2014 | 11:25 PM
2009blackpearle's Avatar
2009blackpearle
Default change them
I did se255 cams 2 years later bike keeps stalling when stopped at a light, I check every electrical thing can think of nothing stopped the problem. so finally im wondering if the valves are not opening properly at low rpm, bad lifter cam lobe chewed off, so i pull the cams out then look at the lifters find small pits in the face on 2 of the rollers, now the big question is where did the pieces go to. flushed out the crankcase cam box strained all the liquid that came out nothing quessing it went into the filter. only thing i can figure is the tiny pieces must have went into the lifter oil fill hole and valves in lifter didnt pump up properly causing the odd stall at idle. ended up using new stock harley lifters since i had to buy new cams had very tiny scratches on one of the lobes and was worried it would start to pit just like the roller face did. so because of the new cam purchase I didnt have enough money for a set of woods lifters. ended up with harley c lifters, no b left anywhere. the c lifters dont pump us as nice as the b's did. for 280 bucks and the possibility of pulling it apart again get new ones and not harley c version either odd thing was ,I didnt see one mark in the oil pump gears
Old 12-01-2014 | 12:15 AM
jammerx's Avatar
jammerx
Don't reuse the stock lifters....
Old 12-01-2014 | 12:33 AM
DTTJGlide's Avatar
DTTJGlide
Comp lifters are less $$ than HD & 10 times better, I've put over 150K on a couple of sets with no problems, good enough for me.
Old 12-01-2014 | 04:57 AM
DHubbs's Avatar
DHubbs
Does the bike still stall at lights?
Old 12-01-2014 | 10:00 AM
2009blackpearle
Default Nope
That solved the problem. Never stalled again and that was 2 years ago now. I still don't like the c lifters. Noisey at start most of the time and low rpm the odd tick till over 2 grand. Get gstermans. Woods. S and s. Just forget Harley c lifters
martin10
Engine Mechanical Topics
12-10-2015 12:46 PM
gmc
03-11-2013 11:40 PM
rbbauer
12-29-2011 07:27 AM
skully1200
Exhaust System Topics
08-08-2011 02:18 PM
thewholehog
05-29-2010 02:41 AM
