Now that I got a Daymaker, I'm thinking of selling it...
Old 11-28-2014 | 11:36 AM
ridedaddy's Avatar
ridedaddy
Originally Posted by Roger That
Maybe you could sell it then. I have the Reflector with no driving lights and it works fantastic....I'll never go back. It is also easily seen during daylight hours which was equally as important to me for safety reasons.
I was riding up from Key West to Marathon this past Monday night. The roads across the islands are pitch black dark at night and I could really see the benefit of the LED's. they lit up the road and beyond both shoulders on low beam. High beam just made even brighter what was already illuminated. Believe it or not, the Key deer are a big concern at night between Key West and Marathon. And you'll get crucified if you hit one!
I've made that ride to the keys several times, this last time I did it however I didn't make it to the keys before it got dark. I completely agree.... It f ing dark out there!! I still have a stock headlight and it makes me want to upgrade for sure. Even here at home out on open dark roads the factory sg light doesn't seem to cut the mustard.
Old 11-28-2014 | 12:47 PM
Roger That's Avatar
Roger That
Originally Posted by 426power
Rogerthat are you running the Harley LED reflector or the trucklight LED?
I have the HD Daymaker Reflector. I had the Trucklite TLP7 on my last SG. The light is very similar but the TL uses two LED's....one for low beam and one for high beam. The HD Reflector has three LED's for low beam and three for high beam and a much better reflector that disperses the light much better.
The HD Reflector is also visible to traffic during daylight hours far better than the TL which was a safety concern for me since most of my riding is during the daylight hours.
Old 11-28-2014 | 01:24 PM
Road Star's Avatar
Road Star
Veteran: Marine Corp
I agree with Cass; everything he stated is spot on.
Old 11-28-2014 | 02:00 PM
user 8373900's Avatar
user 8373900
Originally Posted by Road Star
Picked it up used.
Check the adjustment. I had to re-adjust severely when I got my LED
Mark
Old 11-28-2014 | 02:37 PM
mikelikesbikes's Avatar
mikelikesbikes
Lots of mixed input but I have to agree with a couple suggestions. First make sure it is aimed correctly. Next the running lights make a huge difference. My opinion is a mixed bag as I had the Daymaker on my Road Glide that took a dirt nap a couple months ago but was a night and day difference over stock. On my Road King I first had just the Truck Lite headlight and the wow factor was greatly appreciated. When I added the running lights the side of the road view really helped tremendously. Night rides are now actually enjoyable and I often stay out late just because I can see so much better.
Old 11-28-2014 | 03:15 PM
Veekness's Avatar
Veekness
Originally Posted by bikerlaw
I use this one. Stupid amounts of light, but totally not DOT legal. Still, it lights up the road quite well. You also need a 12 dollar ceramic plug to withstand the extra heat of a bulb almost twice the power of the stock 55/60. Twenty bucks total. A set of ten dollar 896 bulbs in the spots add a bit of extra light as well.
I have the same H4 but at 90/130 watts plus a couple of Wagner 4509 square beam 100 watt landing light bulbs in the spots that I got for nine bucks each from Amazon...wired in with a Bosch relay...for well less than fifty bucks I have phenomenal lighting that cannot be equaled by any high buck trendy lighting...period. my riding partners didn't believe until when a cage almost cut one of them off & I hit the switch...damn near welded their eyelids to their eyeballs. They couldn't convert fast enough!
Old 11-28-2014 | 03:25 PM
Veekness's Avatar
Veekness
Originally Posted by HarleyGTP
Using any of those "plug and play" high intensity bulbs is a recipe for disaster. The electrical system is designed to draw a certain amount of amps through those wires. You start increasing that, you run the risk of burning up an electrical harness.
You could have saved yourself some heartache if you would have just done some research on that particular light. Many say the pattern is narrow and concentrated. I've even seen some good videos.
I have the LED reflector with LED reflector driving lights. I absolutely love it.
Nah. Just make certain you have the ceramic plug & upgrade the spotlight wiring when you wire in the relay. If yer skeered about the headlight wiring just go a size or two bigger. The bigger H4 DOES generate more heat and I agree about not using one in a small bucket...but this is a TOURING forum so that infers that we win have big buckets...I'm telling ya, folks are missing the boat & spending a LOTTA money on lights that just don't get the job done as well as my alternative. Yes, they do draw more current but shouldn't over tax the charging system on a healthy Harley.
Old 11-28-2014 | 03:52 PM
Hausguy's Avatar
Hausguy
I disagree completely. I've been buying bulbs like these H4's for years http://www.ebay.com/itm/H4-9003-HB2-...3ffdb6&vxp=mtr and they last about a year (I ride about 20K miles a year). The Super White 5000K are much brighter than stock - the 6,000's are a tinge blue but these are plenty bright. Add along some brighter 896 bulbs for the spots and you are good to go. These run $5 each shipped and I just keep an extra in the bag.
I can't understand spending so much for LED's unless you're into the look of the lamp.
Old 11-28-2014 | 04:00 PM
Veekness's Avatar
Veekness
Right on. I pay thirteen bux and change for the H4's at my local auto parts store...they source them from The Lighthouse...4507s from Amazon...relays available anywhere
Old 11-28-2014 | 04:11 PM
Hausguy's Avatar
Hausguy
Nothing needed with these. Just plug'em in.
Quick Reply: Now that I got a Daymaker, I'm thinking of selling it...
