Today's Bitch!!!!
Today's Bitch!!!!
Welcome from Kuwait-now I vow I will never ride or get caught in the rain again!!
Here in Kuwait-it just rains dirt and pollution!!
Sooo-spent last 3 evenings cleaning my brand new Road King Classic with 267 miles on it!!!
However-won't be riding it for a while again until the dealer here sorts my problem out.
Bike is running like "****" as the mixture is so weak-like white plugs.
Contacted them 4 times-as getting Screamin Eagle pipes-ECU upgrade & air filter to Stage 1.
So during buying process-they could not stop calling me-now they don't give a crap about me not wanting to ride.
9 days on and I still await a phone call-"yes sir-we promise to get back to you ****"!!!
Meanwhile-I keep polishing!!!
Ride hard & be safe guy's & gals
Bitch over with!!!
Bitch over with!!!
you cannot judge mixture by plugs- that went away with points and carbs.
really the mixtures today are so precise- and gasoline additive packages have detergents and Domestically often ethanol...staring at a plug, you might as well get a crystal ball.
mixtures can be evaluated in real time with a voltmeter on the o2 sensor- that takes some background knowledge.
and it sounds like you are in the hands of the dealer you have chosen to attempt tuning or performance work on your ride.
after you wash, wax the bike. s100 works well, but any of them will-- nufinish can be good for those of us in warm climates as it will dry and haze over when warm.
get one of those california car duster wax mops- they work great for desert dust and grit
throw an old bed sheet over it when parked at home
mike
mike
Bitch over with!!!
Bitch over with!!!
I guess I am "oll school" and thought the plugs would still tell me anything I needed to know regarding the condition of the engine:- i.e light brown-good condition good mixture etc-sooty plug-too rich etc etc
I know with all computurised mixture control/injectors things are different-but I thought plug colours still told the same story!
Ok-you live & learn-but bike still runs crap!!!
You can still read plugs but you have to look down inside the threads at the insulator with a magnifying glass:
Remove the spark plug and examine the INSULATOR (the porcelain) color. White is lean and black is rich. Best color is a tan to grayish-white. White means main jet is too small (lean) and black means main jet is too big (rich).
Use common sense and don't do this if it is unsafe.
The plug shown in the middle is the correct color
The correct location to read the plug depends on what throttle range is being checked.
Shown below, unleaded fuel leaves a light tan near the bottom of the insulator to indicate the A/F ratio.
Unleaded fuel and ethanol fuels like E85 make reading plugs a bit more difficult because they burn cleaner and leave fewer deposits on the plug. Confirming readings with a wide-band oxygen sensor and/or quarter mile times is a good idea.
From the title I thought this was thread about contemporary women, Ha. Anyway forget trying to read plugs in an EFI, hook up to an O2 sniffer if you want to know your tune condition. Your environmental situation isn't the greatest for your bikes finish, might as well accept it now and start enjoying the ride.
Thanks for info
No leaks I can tell.
Greetings back!!
