Taillight removal
I believe the op is trying for the later model Street Glide look and needs wiring information.
Ok if you're willing do body work & paint you may be able to do this. Your gonna need '10 up bar light, '10 up fasica light with brake light((67774-10) and wiring harness that exits fascia light to under seat where it connects. The bar light plugs into the fascia light on '10 up. I am not sure if "10 up fascia light will fit in your fascia it may just don't know. If all above works the '10 up harness from fascia light to plug under seat will need some modification. You'll need to replace the connector on '10 up plug end that connects under seat. It's pretty easy just have match to current harness plug and match color for color. I have pn's if you need them for connector & pins.
