2007 Wheels on a 2011
The '07 wheels are both 3" rims and have 1" bearings, while your bike has 25mm. The rear hub isn't wide enough to fit in your swingarm and won't work! There is also no tyre available to fit it that will compare with your stock rear tyre's load rating. The front can be made to work.
The rear wheel will not work as the 09 and up bikes have a cush drive for the belt pulley which is parts of the hub as opposed to the 07 which utilizes a bolt on belt pulley. Widths are also different between 07 and 09 on the rear wheel meaning that a stock 16x3 is 2" narrower than the rear wheel on 09 and newer bikes. Si there a way to make it work? Maybe. Is it worth the time or hassle? Not really in my opinion. All that to run a skinny 150 tire on a bike that comes with a 180.
Front wheel should work with a bearing and crush tube swap or a front axle swap.
ks_steve
09-04-2015 06:09 PM
