How many times is a primary chain adjustmenr needed
In reading thru these posts, it seems that the automatic primary chain adjuster I currently have on my 2011 RK may cause premature bearing wear
To hopefully prevent this, I have been thinking about getting the Baker attitude adjuster, or something similiar, for my bike.
The $200.00 for the adjuster seems a bit stiff, but if it will help bearing wear, it may be worth it.
However, I'm having a hard time justifying spending the $1000.00 for the Baker cover so I can adjust the primary chain. I can buy alo9t of primary cover gaskets for $1000.00.
I am relatively new to the Harley world and have never owned a bike that had the manual primary chain adjusters.
So, my question:
- How often does the primary chain need to be adjusted??
Thank you
Steve
So, my question:
Thank you
Steve
on evos, check about 5000 miles....not that I had to make an adjustment at each check.
The primary chain will have tight and loose areas-...make sure the tight parts are not tighter than spec...the loose parts might be sloppy.
I swapped both my Evos to the Hayden M6, about the best $75 I spent on those bikes.
smoother downshifts, no snatching or grabbing in low speed operation. a simple spring keeps tension correct. Both my evos, the original plastic shoe was about worn out at 50,000 miles or so--- the Hayden comes with it's own shoe.
( that's the evo version- I have not used the twin cam version)
The evos had a primary inspection cover in the primary, so easy to adjust.
Mike
Mike
Steve, you're right to be suspicious! If you have any plans to service your own bike, such as adjusting the chain, buy yourself the service manual, which will give you chapter and verse on when and how. Checks are at around 5k miles, but that doesn't mean an actual adjustment, as Mike points out.
Seems I can check the adjustment when I change the primary fluid
( i dunno- I am happy with the stock adjuster on my 09...so far).
I did have a question about spacers and tension when I did my first Hayden ( 20+ years ago) and I called and Mary answered the phone and answered my question- I really appreciated that.
install time under an hour if you have the gasket and have been inside the primary before.
With both of my Haydens- as my chains were around 40 or 50K, I guess they were already as stretched as gonna be....I've never had to do anything to them.
Once the tension is set with teh shims- the spring reacts constantly to the chain's tension
Mike
FWIW, I have used the Hayden and didn't really like the chain bouncing up and down (see their video of this in action) as the demonstrator gets on and off the throttle. And if you listen closely, you'll hear the classic "clunk" at start-up...my Hayden did and also when going into gear from neutral.
Yes, Baker suggests checking the chain adjustment about every 5000 miles and Hayden suggests 20,000 on theirs. My 2012 UC, now with the Baker and almost 6000 miles, has needed no adjustment since its install. Personally, I think 5000 may be conservative and 20,000 is a bit too optimistic for my liking.
Like most other "auto adjusting" devices, the idea is fine but the practice is, in my opinion, not quite where it should be. I just like the idea of making adjustments that meet MY needs instead of accepting the tolerances of someone else.
Go w/ the Baker. You control setting up the tension. Not some springs AND shims. If you go M6 you'll probably have a real tight chain until the chain wears into the shoe as well.
Check out the Baker, the thing is heavy duty. I had the M6 but never installed it.
You'll have to pull the compensator as well to install the Baker.
