Lowering my road glide
I have tried to search for other post but cant seem to find any, My question is have any of you folks used the lowering blocks I see on jp cycles are any other site. I see were some say they make the shocks rub the bags, don't want that. I guess I could just buy some streetglide shocks but was hoping for a little less out of pocket money. Any and all responses will greatly be appreciated. Thanks
alot of us use lowering blocks- mine cost about $16 on ebay.
They allow me to use 13" shocks and have 2.75" suspension travel.
previously I was using the 12" SG shocks w/ about 1.75" travel.
guess which gives a smoother ride?
ride height about the same either way.
no bag clearance problems- I am not using the lowest setting which is gained by changing the shock angle ( each hole is a different height)
the ride is ok for day rides- I go back to stock height when touring
the touring shocks were changed for 09+, revalved compared to the earlier version
one thing with a $16 part- have a look every now and again to make sure the things are not falling apart.
on my evo bagger it came with white brothers lowering blocks ( $80)- never a problem with these. white brothers is gone they are now sold as Burly.
mike
mike
Received 4,482 Likes
My stock shocks developed a leak, so I bought a set of take off shocks on eBay for $50. I didn't even realize they were street glide shocks until I got them. From reading the forum, I was worried that the ride would be horrible, but to my surprise, they ride great, better than my old ones anyway.
They are about 3/4" shorter. The ones I bought were from a 2011, so maybe there were some upgrades made by harley from 06-11, not sure. I would rather buy a set of takeoffs than run lowering blocks. For $50, it my be worth it for you to check into it.
Why do you want it lower is the real question. If it is for parking lot maneuvering, go with air ride. If it is for the cool stance when crusing the hood, go with air or lowering blocks. I think air ride gets you the best of both worlds, but it's more expensive than lowering blocks, but you get on the fly adjustability.
