Messed up ....help please
Old 11-15-2014 | 05:43 PM
nevada72's Avatar
nevada72
Originally Posted by stro1965
I have used heli-coils but never a time sert on the derby cover.
Did you use heli-coils in the primary cover tin?
Old 11-15-2014 | 06:11 PM
Stiggy's Avatar
Stiggy
Unless they changed something recently, HD primaries are still aluminum, No?
Old 11-15-2014 | 06:12 PM
qtrracer's Avatar
qtrracer
I need someone to explain how his inner primary is tin? LOL
Old 11-15-2014 | 06:14 PM
smitty901's Avatar
smitty901
Originally Posted by 05UltraBob
There is certainly a Heli-coil, or better yet a Time-sert that will fix that issue.
Time serts are great but costly to fix something so small a Heli-coil should work fine
Old 11-15-2014 | 06:15 PM
nevada72's Avatar
nevada72
Here's the part I am referring to -
top
bottom
It's designed specifically for thinner metals whereas I believe (which means I could be mistaken) heli-coils and Time-Certs are meant to be used in thicker material.
I had a magnesium block on a Porsche a while back. It had Time-Certs to hold in the head studs, as they were prone to pulling out. In that case, the hole depth just exceeded the Time-Cert length.
Old 11-15-2014 | 06:18 PM
qtrracer's Avatar
qtrracer
Just heli-coil the damn thing. It'll be fine.
Old 11-15-2014 | 06:19 PM
nevada72's Avatar
nevada72
Generic reference to sheet metal douche bag. He's referring to the primary cover that the derby cover screws onto. Maybe you screw your derby cover to an inner primary on your awesome 2008 , "light years ahead", of a new SG. But most of use simply bolt them on to the outer TIN.
Get over the fact that I put you in your place on a different thread. Lol.
I stand corrected - I believe you are right. But, I still think it's not deep enough for a heli-coil. I could be wrong as stated earlier.
Old 11-15-2014 | 06:24 PM
qtrracer's Avatar
qtrracer
This is getting hilarious.
Old 11-15-2014 | 06:26 PM
nevada72's Avatar
nevada72
Sure is. Tell us more how the derby cover screws onto the inner primary. LOL
Old 11-15-2014 | 06:47 PM
Gliden's Avatar
Gliden
Omg..........
Quick Reply: Messed up ....help please
