Installing a tour pak on 12 Street Glide
So after spending about 2 hours searching the forum I cant seem to find exactly what I'm looking for.
I am going to put a tour pak with lights and speakers on my '12 Street Glide. The pak came from a 2011 Ultra. I am a little confused about the light situation. I was told I will need some adapter because the harness on the bike will not just plug into the plug on the pak? I have been reading about the speakers and I'm pretty sure I can buy an overlay harness or make my own? Will I need an amp to power the speakers or will flashing the radio work fine?
Thanks in advance
Josh
Thanks in advance
Josh
I've been going through this myself on my 09 SG. the 09 is a little different in that it does have a center tail light. and the tri bar light is wired differently.
That being said.
on the 09 the factory tour pack light connector is located under the left side side cover. Unfortunately on the 09 that connector is used for the tri bar light. Maybe on the 10 and later models it is open.
In any event I would look under the side cover to see if there is a three wire connector for the lights.
As for the speakers, wires and a flash is all that is needed.
That being said.
Thanks in advance
Josh
Thanks in advance
Josh
That being said.
That being said.
A lot of people do this, it's just hard to explain and many ways to wire it. I added the ebay cvo style wrap LED light and side lights, and was able to make a connector to attach it to the wire under the fuse cover of the bike. My stereo is all after market so wiring my speakers to my amp didn't require a special harness just speaker wires. My tour back does have brake lights with the CVO stlye light and air wing rack light but I couldn't figure out how to wire turns into it.
There is no harness (at least that is what Bruin found out). The 11-13 street glides do not have the same harnesses for them to plug into.
If you had to get a harness it would be the ultra overlay harness but the street glides 09 and up have a round plug and the ultra has a square plug. Aftermarket company's like custom dynamics might have something as well. I bought mine from ridetimetechnology but I think there closed now.
larry69fatboy
01-09-2009 07:46 PM
