Help with noise
Help with noise
I have a noise that sounds like it is coming from the front end of my 2010 RKC that I am having problems pinpointing and would appreciate any help you guys can provide. It is sort of a "swish, swish, swish" like something is dragging slightly. It isn't loud and I don't think it is coming from the drive train because it slows down as the bike slows. If I let off the gas and pull in the clutch it gradually gets slower until I stop. I had a little pulsing in my front brakes so I replaced the front rotors with fully floated rotors and the pulsing is gone, but the sound is still there. I had the bearings replaced last year when one blew, but I thought it might have been the bearings so I pulled them, but they look fine and don't have any binding and aren't loose. I have read quite a bit about compensators going bad. I don't have more than a normal amount of metal fuzz on the drain plug of the primary, but could the noise be the compensator? My bike runs great, I just don't feel I can ignore this sound, and I would prefer to not have to take the bike to the dealer.
Thanks to all.
Thanks to all.
See if the noise changes with a tiny bit of front brake pull. If so, may be a sticky caliper piston, not retracting and causing brake pad drag. If that isnt it, I would look at wheel bearings. When you spin the wheel in midair, no noise, but with weight on it, the bearing loads and you hear it.
msamarah86
09-07-2011 10:56 AM
