How stiff are your wheel bearings?
My 04 RK has very stiff wheel bearings, especially the rear. They are dead smooth in their motion, just bloody stiff. I've no Harley background, so I just don't know if this is actually normal for Harley wheel bearings. They move smoothly and quietly and there is no heat buildup when riding. Just darn stiff. There is no casual spinning of the wheels.
Yes, this is off the bike as well. Perfectly smooth and silent, just quite stiff. Just don't know if this is a weird Harley type thing. Normally, I'd expect the bearings to be loose at this point (10 years and 50+k miles). But, I've been surprised by other things, so I don't want to buy another set of bearings only to find them just as stiff.
My bike is eight years old with 80K+ and my bearings front and rear on both sides have always been like what your describing. They are still smooth and quiet on the road and have no play nor signs of wear, (seals leaking, play). I've also always done my own work on my scoot so I know it's right. I chalk it up to no high pressure water on the seals when washing. I've read where some here have carefully removed one side seal and repacked the bearing, but have not tried that trick yet. If theirs no play and they feel good to you, run them. I recommend checking them at every tire change.
aka BOB
I thought about the inner spacer causing a bind, but after 50K, would think that would have loosened up. Off the bike pretty much eliminates any other binding, and original '04 bearings shouldn't be chinese, so probably not out of tolerance manufacturing. Some kinds of grease will dry to stiff clay consistency; that could cause it. I don't believe in ride till it breaks; any question on wheel bearings, I pull the wheel, pull a seal, and visually inspect. If I'm still not satisfied, I change the bearing. I have cleaned bearings and re-greased them when the bearing itself looked and felt fine when clean and dry, but you can feel the wear and a bit of roughness in a lot of them when they're clean.
For folks that don't have the tools and have to take it to a shop, I understand that could be expensive; if you've had a wheel off, you're only a bearing puller away from having the tools. Unfortunately, cheap bearing pullers don't work well on tight Harley bearings; to do it easy and damage free, one like this is better; I have one, works great.
One last thing - I've seen a lot of bearings with a thin thread of grease on one side of the bearing cage, none actually on the *****. It'll sling out and coat the ***** pretty quick, but you're still putting a full on them dry for a few revolutions. I always check for enough grease (I've found a few bearings with no grease in them!) and rotate them by hand till it's spread on the *****.
Amazon.com: HARLEY DAVIDSON WHEEL BEARING REMOVER and INSTALLER TOOL: Automotive
The wheel bearing puller,installer above I actually own. haven't had a chance to use it yet though but its a quality made tool. I bought it to use on my Heritage but sold it before I got a chance.........
