rear shift lever removal
Old 11-02-2014, 09:27 PM
Rampant's Avatar
Rampant
Rampant is offline
Default rear shift lever removal
I hate the rear shift lever thing. Why is this thing even here?? Just takes up space.
I see kits to remove it but the cheapest I've found is 60 bucks and it looks like it's just a spacer.
Anyone removed their rear lever and have any idea what it takes? I'd rather go to home depot and spend like 5 bucks on a piece of black PVC pipe or something like that.
Old 11-02-2014, 09:32 PM
mikelikesbikes's Avatar
mikelikesbikes
mikelikesbikes is offline
I don't know where you got 60 bucks for a simple spindle cover but you need to look elsewhere. I hate the rear lever myself and refuse to keep one on a bike. Here is one from eBay (although not crazy about it) and have nicer.
Old 11-02-2014, 09:43 PM
SafetyMan's Avatar
SafetyMan
SafetyMan is offline
The "kit" from Harley was under 20 bucks IIRC
Old 11-02-2014, 10:24 PM
firemeat's Avatar
firemeat
firemeat is offline
Take the rear off. Slide the front shift lever to outer edge (position where the rear lever used to be). Measure the gap, not including the oem rubber spacer already there. Then take the rubber from the rear shifter peg. Cut it to that size. Now you have a spacer that will work to eliminate the rear shift lever and looks kinda cool.
Old 11-02-2014, 10:33 PM
Guntoter's Avatar
Guntoter
Guntoter is offline
H-D also sells a folding rear shift lever, giving you more room on the board. I have one on mine but really don't use it folded a lot as I find I have enough room as it is normally, and usually have my feet part way on the highway pegs most of the time. However I use the rear lever for every upshift. After using it I cannot imagine ever going back to sticking my boot under a shift lever again.
http://www.harley-davidson.com/store...g-heel-shifter
SamStone's Avatar
SamStone
SamStone is offline
They put that lever there as a spare.
Old 11-02-2014, 10:35 PM
dochawken's Avatar
dochawken
dochawken is offline
Go to Ace Hardware and get a 3/4" chrome spacer..3$
Old 11-02-2014, 11:36 PM
MICROBEAT's Avatar
MICROBEAT
MICROBEAT is offline
mine came with the single shifter conversion, wanna trade? (i miss my heel shifts..sigh)
Old 11-02-2014, 11:53 PM
Rampant's Avatar
Rampant
Rampant is offline
Sure!
Old 11-02-2014, 11:59 PM
mike5511's Avatar
mike5511
mike5511 is offline
Up shifting with your toe is hard on the Wing-Tips!!
Quick Reply: rear shift lever removal
