rear shift lever removal
Old 11-03-2014 | 08:57 PM
dgdamore's Avatar
dgdamore
I took off my front one and use just the back one only.
  #32
Old 11-03-2014 | 09:52 PM
Def Mute's Avatar
Def Mute
Take both levers off...
Then put the front lever back on, on the outer spline. Measure the empty space from inner side of the lever to the primary case where the shaft goes through. Be sure to pull on the lever to get the correct measurement.
Then, get a piece of pipe that will fit over the shaft and cut to length to fill the gap. Paint it black, or pink if you like. Won't cost $20 bucks, and works. Ask me how I know...
  #33
Old 11-03-2014 | 10:27 PM
Rampant's Avatar
Rampant
Looks like that's the plan this weekend
  #34
Old 11-03-2014 | 10:38 PM
TriGeezer's Avatar
TriGeezer
Thank goodness the later posters started calling it properly "heel shifter". WTF is a rear shifter? Is that some kind of seat accessory?
Whatever...I like it and am keeping it. I don't tromp it, so doubt I'll break the seal or break the trike in half. It is quicker when ya need to get up and go....and it doesn't scuff my black and white patent leather shoes.
  #35
Old 11-03-2014 | 11:31 PM
UltraClassicElectraGlide's Avatar
Guess I've ridden Harley's for so long that when I rode my son-in-laws Electra Glide Classic during the summer without the rear shifter, it just seemed out of place. Never got used to the feel, and yet I rode Honda's for a zillion years without the rear shifter before riding Harley's.
While I like the cleaner look of a single-shifter, it's twin-shifters for me on my Ultra. Yeah, that's what I call it since the heal on my boot isn't what makes contact with it, and the word 'shifter' sure shows up a lot in my Harley service manual.
  #36
Old 11-04-2014 | 07:30 AM
Def Mute's Avatar
Def Mute
IF we have to explain, you'd never understand...
  #37
Old 07-08-2020 | 01:31 AM
Pop Rivet's Avatar
Pop Rivet
Stage III
Default Did it
Originally Posted by firemeat
Take the rear off. Slide the front shift lever to outer edge (position where the rear lever used to be). Measure the gap, not including the oem rubber spacer already there. Then take the rubber from the rear shifter peg. Cut it to that size. Now you have a spacer that will work to eliminate the rear shift lever and looks kinda cool.
Yes the only way to go. Also puts lever out into a better position
avcaruso
03-27-2013 09:59 AM
mikelikesbikes
12-11-2012 12:51 PM
Ed45
08-23-2012 07:23 AM
shabs
05-13-2011 05:20 PM
Heritage07
12-29-2006 08:51 PM
Quick Reply: rear shift lever removal
