Fuel Moto head pipe install
Reading the instructions for the ceramic coated fuel moto head pipe, it says to basically avoid handling the pipe with bare hands I presume to avoid the transfer of oils that might discolor the pipe. On completion of the install, should I take any precautions like wiping it down with a microfiber work cloth to remove any finger/hand prints? Should I use any type of alcohol (like de-natured, not bourbon!) to clean the surface? Or is it much worry about nothing?
Thanks!
Thanks!
Any external parts installed on any bike should be wiped down before being ridden/run. With or w out gloves you will get dirt and grime including oils on the parts just from handling the items so any quik evaporating cleaner will avoid discoloration from these and heat. I use brake clean personally even on painted surfaces(make sure not to leave on there for long) and spray wax wipe down afterwards is a plus but not necessary.
whatever you do you are bond to get something on them. Latex gloives will leave stuff to. I would use some cloth gloves and then use windex or bkrae cleaner to really wipe down every bit of them before you start it. And in the future if you touch them in anyway or get oil or anything on them clean them again. good luck, and you are spot on with the forum........ they will save you a lot of trouble
We have just released a new video that covers the complete install of the Jackpot 2/1/2 head pipe on 2009-2015 FLH models. It goes over everything start to finish from removing the factory exhaust to installing the Jackpot pipes and heat shields. The video can be viewed here:
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Jackpot 2/1/2 Installation Harley FLH Fuel Moto head pipe header exhaust - YouTube
I just watched the video and didn't know there is a gasket where the cross over mates up to the JP pipe under the bike. Can cause decel pops if not installed properly.
