Faulty throttle position sensor wiring
Just a warning for something you may want to check out. Our 2012 Ultra Classic TriGlide was enroute to Morro Bay, when I lost throttle in cow country. I could start it up, but got absolutely no throttle.
In another thread, I detailed the entire experience. But, the short story was that the pins in the connector at the throttle position sensor (behind the AC) were corroded and fried. The dealer that did the work, claimed this was common, and that Harley has tried several time to fix it. As a testimony to the frequency of occurrence, the dealer had 12 repair kits in stock.
So, from now on, as part of my oil change frequency check over, I am going to unplug this connector and examine the pins and wires. You may want to do the same as a 1 minute preventative measure could save a lot of aggravation.
I have seen the wires under the sheathing break and cause this issue once the bike is hot. My had an issue for a long time and we were talking to an HD mechanic one sunday and he said check the wires under the sheathing. Sure enough one was frayed enough that when it would get hot it would lose contact.
He soldered it up and it has been fine ever since. It always a good idea to put some dielectric grease on that connector plug as well.
It is kind of amazing that this is happening, I mean I am almost positive that there was a TSB or something put out about this problem several years ago. It was before your trike was even built, but it did address this exact same "fretting" problem. I want to say the bulletin was sent out in '10 but it could have been '11. I know it didn't include your trike, because it didn't exist yet, but it should have been corrected at the build or at least addressed at the dealership.
The bulletin stated to pull the plug and inspect the pins for any signs of fretting, and if it showed signs, then replace the pins and apply dielectric grease to the plug. If it showed no signs of fretting, then apply dielectric grease to the plug.
TriGeezer
18
12-07-2017 07:47 AM
FireHogRider
Electrical/Lighting/Alarm
18
05-04-2017 11:37 AM
