FLHP stator, compensator question
10-27-2014 | 09:13 PM
I did one on my '00 FLHRCI didn't use any kind of sealant no problems
10-27-2014 | 10:36 PM
I've done this several times for friends. I always use silicone- black as both lubricant and sealer to prevent leaks. There is a thread here that you can do light grinding on the inner primary and remove the rotor without removing the inner primary. Really worth the read, makes the job much simpler and doesn't create any problems.
10-28-2014 | 05:51 AM
The warranty covers any leaks
so get them to fix the leak and then find out what you have inside. Used to be they would replace the whole stator if the wire coming from the case leaked but now I've heard they only replace the rubber seal.
10-30-2014 | 11:49 AM
Thank you all for the responses.
I need to remove the inner primary because i want to change the shifter seal. Also, it seems it would make changing the stator a bit easier.
I think I'll also go with the black RTV silicone. Just makes sense
Thank you all again
10-30-2014 | 12:04 PM
+1 for cycle Electric but the HD one has a revised case plug. I did mine yesterday and it charges at 14v at idle.
05-03-2020 | 05:33 AM
Quote:
Originally Posted by
soft 02
I know this thread is old. I hope you get this
Did you install the HD stator or cycle electric?
Which one charged 14 volts at idle
05-03-2020 | 08:35 AM
jordan1200
I went with cycle electric. Still have the same one in the bike and 140,000 miles.
DianneB
05-17-2021 08:54 PM
IKnowNot
Electrical/Lighting/Alarm
12-07-2014 04:26 PM
jimaw2
Shovelhead
07-10-2013 04:32 AM
WindJammer
01-18-2013 02:21 PM
mackibc
10-03-2011 07:33 PM
