Adjust Ultra Clutch
Old 10-10-2014 | 05:35 PM
prezflyr's Avatar
prezflyr
Default Adjust Ultra Clutch
While I had the primary off of my 2009 Ultra I thought it a good time to take up the adjustment slack in my clutch cable. I slid back the rubber boot and backed off almost an inch of free play. I removed my clutch lever and cleaned and greased it. There was a lot of slack in the cable at the lever. I backed off the clutch locking nut ant tried to screw in the center adjusting screw. The center adjustment screw would not go in at all. I removed the screw and looked in the hole and could see the mating piece. I ended up screwing out the inch of cable adjustment I had screw in earlier. I am back where I started. Anyone have any suggestions with an inch of free play in the cable the adjustment screw will not move in without opening the clutch plates?????
Old 10-10-2014 | 06:51 PM
smithbrl's Avatar
smithbrl
You should be turning the adjustment screw "out" a few turns then back in til it bottoms lightly. Then back it out 1/2 to 1 turn.
It's moving the clutch plates because it's already bottomed out and you're pushing the plates open with the adjustment screw.
I back off on the cable adjustment til the lever hits the left grip, but I don't know if that much slack is necessary or not. Just the way I've always done it.
Make sure the engine/primary/tranny is cold before you do the adjustment.
Old 10-12-2014 | 02:13 AM
HammerBACA's Avatar
HammerBACA
2nd Gear
Old 10-13-2014 | 09:23 AM
62hdbiker's Avatar
62hdbiker
[QUOTE=smithbrl;13307459]You should be turning the adjustment screw "out" a few turns then back in til it bottoms lightly. Then back it out 1/2 to 1 turn.
X2
Old 10-13-2014 | 09:35 AM
SeaZund's Avatar
SeaZund
sounds like your adjusting screw was already bottomed out when you started. Next time, after loosening the locknut, back out the adjusting screw 3 or 4 turns so you know it's not against anything. Then screw it back in until you feel the resistance you're looking for. At that point, back it out 1/2 to 3/4 of a turn, then adjust the cable for the proper handle feel.
Old 10-13-2014 | 09:38 AM
62hdbiker's Avatar
62hdbiker
Originally Posted by HammerBACA
Good video.
Don't lay your derby cover on the steel diamond plate table, chrome side down - like he did in video. Maybe lay it on newspaper.
Old 10-13-2014 | 01:31 PM
Nikogto's Avatar
Nikogto
How often should you adjust the cable, or miles? I've got 14k, no real issues at all. Is it a good thing to keep it adjusted up at a regular interval?
Old 10-13-2014 | 05:59 PM
Mr HOG's Avatar
Mr HOG
I adjust my clutch and lube the cable once a year. Cable lube being the most important thing that get overlooked.
Old 10-13-2014 | 07:42 PM
Hausguy's Avatar
Hausguy
Newer cables are teflon lined and lubing them is a no-no.
Old 10-14-2014 | 06:48 AM
Nikogto's Avatar
Nikogto
What year did they start that? Mine is a 2007
peepa
General Topics/Tech Tips
16
10-01-2016 05:36 PM
TinCupChalice
10-21-2015 01:20 PM
lost_roadking
07-19-2013 02:47 PM
yota
12-11-2011 09:28 AM
Iron lHorse
08-28-2011 08:37 PM
Quick Reply: Adjust Ultra Clutch
